Old 25-01-2007, 15:31
Yeah they're in the diff.
You need to compare the gearbox ratios not the diff ratios
Old 25-01-2007, 15:39
Sharas's Avatar
Sharas Sharas is offline
Hm... Im a little confused now (the gearbox ratios are also a bit different, thou the 4 gear is the same), but dosent the final drive ration depend on the diff? (so if compared to an s13 i should have shorter gear ratios, since the final drive is different).
Or am i totaly wrong here now
Old 25-01-2007, 15:43
No if you want to compare it to an S13 its fine, but I though wanted to see what the effect of using an S13 gearbox would be in an S12?
Old 25-01-2007, 15:49
Sharas's Avatar
Thought so, thanks for clearing out everything for me .
P.S. Since the gearbox is together with an ca18det engine, it makes more sence to compare the final setup with an s13 (in my opinion).
Old 25-01-2007, 16:00
Yeah thats fairly good reasoning if you ask me
Old 16-06-2007, 17:11
ChEsTeR ChEsTeR is offline
Is this pisble that i have dif ratio 4,3 ???
I chcked my speed with GPS today and at 3000 rmp on 4-th gear it says 80km/h after some calculations it turns out 4,34 mayby im wrong with my math. Weels diameter is 615 mm 195/60/15
Old 16-06-2007, 19:41
Would work out that way to me as well, but I can only think your rev counter is over by about 400 rpm
Old 16-06-2007, 22:55
I chcecked the rev counter with the piggy back and it shows the same revs. Mayby my GPS is a bit of. It is inacurate ba 5-10% so it would not be used as a guiding gizmo.
