Old 21-04-2007, 10:45
or get one for an S13 like others have done which are lighter!
Old 21-04-2007, 11:20
Still hurts when you drop them on your feet though lol.
All the time I've been in France I've never seen a single S-chassis car so can only imagine getting parts is near on impossible.
Old 21-04-2007, 15:47
Ok,
With your advices, remove the starter was easy, thanks!
Some pics:
I saw some new/reconditioned starter, in France, but:
-they have a "cover" on gear area: http://www.altdiscount.com/affichear...mmat=0&moteur=
According too me this fit: http://www.altdiscount.com/affichear...mmat=0&moteur=
I found this site too: http://www.woodauto.com/Unit.aspx?Ma...I&Ref=S114322A
Old 22-04-2007, 15:22
Can a 1 kilowatt model fit on mine? What is the cover on th e gear, like a cap?
Old 22-04-2007, 18:20
Just clean the solenoid
Old 25-04-2007, 19:58
Ok, some news...
It seems it isn't the starter, test mine and an another.
I tested many relays (specialy gray relay near battery, controlled for ignition right?).
battery charged and tested
Ok, let me explain my troubles:
2 wires fits on the starter: one black/yellow little size ordered by ignition, one black/red normal size which go to the battery.
When the plugs are on the starter (metal shield of starter on a ground of the car), when i join together the 2 wires said upper, by an external wire, starter work perfectly (gear exit and turn), but when i turn the key only nothing appear.
I know that my english isn't good, but in my mind it's the black/yellow wire that is in fault because the continuity of the "normal" wire exist, no doubt about it.
The solution i expect to install a start button relay (how many Amperes?) to command the ignition.
Do you have any hint or help about my starter trouble?
Cheers.
Old 26-04-2007, 00:17
Yeah sounds like the starter signal wire at the back of the igntion barrel is at fault.
I would trace it back to there before thinking about adding a button
Old 26-04-2007, 01:13
According to the diagram where is this wire pass?
Cheers.
Old 26-04-2007, 22:49
Ok is this pic correct i'd like to fix this tomorrow:
Old 27-04-2007, 00:27
i had exactly the prob you have, i was on holiday and i turned the key, nothing, i temp wired a switch from the batt through switch to starter, was fine, and then after about 1 and half weeks it worked again, this was about 6 year ago, and has never had a prob since, so i cant solve your prob, but i can say, temp wire a switch in for now while you test the rest.
