Old 05-03-2009, 02:03
kennyboy's Avatar
kennyboy kennyboy is offline
Thumbs down Rear shocks
Originally Posted by umpkin View Post
you can get kyb inserts for the front (kyb P.no 365013), although they seem to be hard to get these days.
for the rears, you can fit mk2 escort uprated rear shocks if the car is lowered for bout £110 pair on ebay, I think kennyboy from this forum has a set on his, if its not lowered then i prolly wouldnt use them as they are shorter and help with lowered loose springs only
on a side not, if kenny reads this, did the escort shocks make much difference to handling???
Cheers.
Hello chaps, rear shocks made a huge difference, loads stiffer but not too stiff as to make it dangerous, weren't badly priced, you need to ask for Mk2 escort turrot topped Spax rear shocks, i payed about £120 the pair with 28 different settings and i only needed to set it at number 12 think it was for road driving and it stopped the spring falling out, the only thing you need to do is change the Bolt on the bottom mount as the nissan one is too small diameter wise and i spaced the bottom of the shocker mount sideways with washers but this could be done with poly or Ally, i will try and dig the part number out for your info,
cheers
Old 05-03-2009, 20:58
black diamond do a full set of disks for the s12, think you can get them from needforspeed.co.uk
Old 06-03-2009, 18:13
cheers
cheers m8, that would be really helpful, as the ones that had turret tops were rs2000 i think, but im sure they where the same mounting as the bottom on the s12 top and bottom, the std mk2 escort ones are bout 4" shorter than the s12 ones.
where did you buy them from also, i live just down the road to burton power, but when i rang them, they didnt really want to help me.
Old 09-03-2009, 08:18
I think the one Ken got were 'motor sport' ones for vertical turrents (a common mod for escorts), stock escorts didn't have them. Try motorsport orientated suppliers, Rallydesign or Roadrunner etc (just two names off the top of my head - I've not looked into this, just trying to help out ).
