Old 15-10-2006, 12:01
s12Rob's Avatar
s12Rob s12Rob is offline
cheers m8, that will be done soon enough, need more power at less boost. lol
anyone got a safc they want to sell
Old 15-10-2006, 17:40
nots13 nots13 is offline
nots13 is an unknown quantity at this point
whats the maximum bost pressure you could run without an intercooler?
1991 Lexus Soarer twin turbo....320 lb/ft from 12psi of boost!! bye bye m3
Old 16-10-2006, 17:44
s12Rob's Avatar
safe i wouldnt go much more than 8 if u have a heavy right foot, it you set the timing up you can run more to stop dett
Old 16-10-2006, 20:25
10psi. After that the inlet temps rise too much and kill any benefits of increasing the boost and so this levels the power out. Fit an intercooler and then you can winde this up by an extra 4psi with a very healthy standard Turbo.
Old 15-11-2006, 19:31
smoker's Avatar
smoker smoker is offline
Default C109
Sorry if this is a stupid question ..doh! but what is a C109 oil filter ?Is that a Fram/Nissan part number and does it have bigger capacity than std. filter ?
Old 16-11-2006, 00:56
Thats a champion oil filter which is an alternative supplier. Its identical to the Nissan item. Halfords stock these
Old 16-11-2006, 12:43
smoker's Avatar
Thanks I'll try Halfords if my motor factor doesn't come up with anything
Old 30-03-2007, 15:17
James H's Avatar
James H James H is offline
Just popped out to grad some, only to be told 10w-50w fully synthetic oil doesn't exsist, is this true or is there a modern day alternative... help?
Old 30-03-2007, 20:08
http://www.driftworks.com/catalog/pr...-5-litres.html
Take it to the guy who told you that and make him drink it....... then kick him in the nuts
Old 16-05-2007, 15:10
Here's a quick one for anyone who's listening. When fitting a T25 do you re-use the old oil feed line or do you have to get a double banjo ended braided hose made up?
