Old 15-06-2010, 02:40
irish s12's Avatar
If you left the dizzy on then did you get it skimmed?
Have you checked to make sure you have sparks and fuel?
Old 29-08-2011, 14:32
Having left this for a while due to other projects I'm still having trouble starting as before, fuel, spark and the engine turns over but won't fire, yes the timing is correct.
Any help appreciated.
Old 29-08-2011, 15:16
tim murphy's Avatar
is the engine turning over fast or slow i.e check out earth . cheers
Old 30-08-2011, 16:09
I think it's a bad earth but I'm buggered if I can find it.
Old 30-08-2011, 21:26
tim murphy's Avatar
i wound go with coil earth first and back track . keep on it . cheers.
Old 02-09-2011, 10:37
fuel
spark
compression
cam timing
ign timing
work through the list.
