Old 08-10-2011, 19:34
paulsilv's Avatar
paulsilv paulsilv is offline
http://www.ebay.co.uk/itm/MOTORSPORT...item5d30a4c98a
SPEC:
Length - approx. 181mm
Width - approx. 77mm
Height - approx. 167mm
Weight - approx. 5.3Kg
Terminals - 12x12x1.2mm flat blade, 6mm diameter hole
Completely sealed Lead-Acid battery
Maintenance Free.
Not sure whether to go for the Odyssey Racing 25 instead though, something with a bit of history and researchable background
Voltage: 12
20hr Cap/Ah: 16
Weight Kgs: 7
Dimensions (LxWxH): 184.7x79x169.4mm
Terminations: M6 Receptacle
Old 30-10-2011, 18:13
paulsilv's Avatar
Ok finally got my arse into gear on this and ordered a positive battery cable from a BMW E39, as the battery in them sits in the boot.
420cm long, delivered for £43. A lot cheaper than buying a race battery and cheaper than buying the cable and parts new.
Just need a cheap battery box now
