Old 21-05-2014, 11:32
martin.herwitson's Avatar
Does the turbo make good boost? could it be jammed or tight? Many of these cars have been stood for long periods now so it could just be that?
Old 21-05-2014, 11:35
Turbo does spool up when stood still can even hear it chatter when throttle is closed quickly so I reckon that's alright.
Got myself a timing light, going to give the injectors plus leads a once over a bit later today.
Old 21-05-2014, 19:13
Here's a question, when setting the timing is this correct:
Bottom pulley to 15 degrees
Set distributor to one gear out to the notch and install
Or set the set the bottom pulley to 0 tdc and then align the dizzy to give me 15 degrees when the engine is running?
Old 21-05-2014, 21:39
tim murphy's Avatar
hi big dave that sounds right disconnect the vacuum hose and plug it engine speed up 2 to 3000rpm turn distributor clockwise see how you go going a write up on my this weekend first you must set the bottom pulley to o and make sure your top pulley mark is at the top of cylinder head and turn engine over with a spanner twice cheers
Old 23-05-2014, 19:31
Tim mate which vac hose do you mean? I'm working for the next few days so won't be tinkering with it...
Old 09-06-2014, 09:14
Cam timing was out by about 180 degrees. The previous owner must have aligned it with the wrong timing Mark on the pulley. Sorted now and acceleration Is all good
Schutz applied underneath, sills surface rust has been treated and painted up a bit. Insuring it tonight and will be my daily for a while!
Old 18-08-2014, 23:50
Nice one. i wish i had seen this post sooner as i was just about to reply and say to check it hasnt had a cambelt fitted incorrectly recently.
i see it alot on the older cars. people getting the cam belt wrong an then compensating by putting the dizzy a tooth out.
Old 19-08-2014, 21:32
Cheers mate, I was shocked and had a mini panic attack and thought there'd be some major damage somewhere but got away with it!
