Old 14-06-2007, 18:02
http://www.nissansilvia.co.uk/vbb/sh...light=tomo%27s
can't you make your own bracket, like the one that i made to blank the t3 wastegate on tomo's t3.
Old 15-06-2007, 00:41
ChEsTeR ChEsTeR is offline
Today i have set AFR on my silvia 12.5-11:1 @ 1 bar of boost. But one thing is bothering me. the car puls better then on 0.7 but after few runs the exhaust mainfold starts to glow. This has never happend in my old car(atuly happend at 0.8 bat of boost on a T2 with no IC). Can the EGR system (mallfunction or not) cos it????? It happend the moment i have replaced injectors and pluged EGR back because i fond out that a vacume line from the intake manifold was of. The plugs are all wite ( the AFR at lower RMP's with no bost is 14.7:1)
And one thing more before tuning it but right after instaling bigger injectors exhaust mainfold olso glowed red even at at low boost and the AFR was much richer.
Old 15-06-2007, 00:54
Sounds like the ignition is too retarded
Old 15-06-2007, 00:56
Mayby i damaded knock sensor harnes during replacing the injectors.
Old 15-06-2007, 01:00
I'm also left wondering if the euro 8 spark engines have different AFM's to the UK ones
Old 15-06-2007, 08:31
I'm preaty shure they have. Because the 4 spark ECU dos not cooperate withe 8 spark MAF
Old 15-06-2007, 08:59
Could explain the higher than expected voltages
Old 15-06-2007, 09:16
so what should i do?
Old 15-06-2007, 09:20
Try to use an S13 afm, but then your work on original afm maybe sufficient
I guess the pin outs on your ecu are different to the UK spec?
Old 15-06-2007, 09:39
The signal cable is the same in both ECU's and the voltage is the same but the 4 spark does not accepsts it dont know why. I will try an s13 one with a lambda.
