Old 09-10-2007, 00:17
I might know someone that may have a set, I'd have to ask him tomorrow
Old 09-10-2007, 01:17
n1 would be a great help, if nothing else, just knowing i have a solution if all else fails.
dunno if you still have my number, ill PM it to you, if you can text me when you find out, i have yours so i will know its from you, ill be messing with it at my mums, close by to you
Old 13-10-2007, 15:47
blitz blitz is offline
americans and canadians use Z31 rear dampers, and 280zx front. there is a "coil over" kit from megan racing and ground control. the megan racing one is USD $1050, but you have to do S13 front end conversion. the rear one is basically coil over with separated springs and collars.
a word of caution: the Z31 has longer stroke so if you car is lowered quiet a bit it will bottom out. I haven't done any of these as I ride on blown AC delco stock replacement.
there was koni sport rear dampers at one time but it's all gone, or buy one used.
Old 13-10-2007, 16:06
i phoned a place today who measured a MK1/2 escort AVO rear shock the silvia one measures 23 inches to the lower washer, and the escort one measures 19.5 to the lower washer, so in effect losing 3.5 in at full length, im not sure if that might be a bit much as the car will bottom out much lower down (which might cause other damage, not that ive ever bottomed it out any way, or could top out if it done have much travel, could that cause any damage?? although spax and avos etc are competition shocks, and seeing them on the TV jump like they do, should be ok
i could always make an adjustment to the rear bolt up section by altering the bracket with some plate and a drill and my welder
a pair of rear adjustable sports shocks for a mk1/2 escort = £100 + £10 P&P from ebay. (avo)
Spax = http://cgi.ebay.co.uk/Ford-Escort-MK...QQcmdZViewItem
AVO = http://cgi.ebay.co.uk/Ford-Escort-Mk...QQcmdZViewItem
