Old 27-02-2008, 06:10
Sharas's Avatar
Sharas Sharas is offline
I am using the s13 brackets, because they came with the engine, so i never even checked if my fj brackets would fit (i just asumed they wouldn't).
Now the thing is that the s13 mounts dont just bolt to the subframe (thats the thing that i was refering to as "travers" ). Seems that i would need to drill a little hole in the subframe, for the little thing that aligns the mount (its closer to the bolt then on the fj mount).
If the left and right mounts are different in this aspect i might have to of the same side. Ill look into this today, maybe make some pic's to make it all clear.
Old 27-02-2008, 07:13
When i fitted my det on the mounts i cut the little locater off my nismo mounts
Old 27-02-2008, 09:23
Just rotate the mount 90 deg's, the dimple is supposed to sit in the same slot that the bolt goes into. I would also recommend not tightening them up until you got the engine in place as you get a degree of flexibility from where they can move up and down in the slot
Old 27-02-2008, 10:14
Sharas's Avatar
Allright, ill see what can be done, when i get back home.
Thou i would have a prob with tightening the mount, once the subframe is back in the car. Basicly theres no room to reach that bolt, i guess i would need some sort of a smart wrench, that i dont have
Old 27-02-2008, 10:22
if you have the fj20 mounts, could you measure the thickness of them in mm please as i was told they where about 47mm with the engine on them, thanks.
Old 27-02-2008, 10:26
Yeah you need to smash the spanner up a bit with a hammer.
This image shows visually how the dimple should sit
Old 27-02-2008, 10:38
who's engine is that mart ?
Old 27-02-2008, 10:47
Nothing to do with me, its just a pic I found.
Old 27-02-2008, 19:57
Sharas's Avatar
Thanks for the help 30psi. Got the mounts in today, everything looks fine for now
Old 07-03-2008, 21:44
Oscar's Avatar
Oscar Oscar is offline
would standard auto box take the power of a det?
