Old 31-01-2007, 10:51
Yeah hubs should be only like £20-30.
Old 25-09-2009, 00:35
nedge2k nedge2k is offline
Administrator
Originally Posted by sideways danny View Post
convert to s13 front hubs and struts and get some of Dan_s14a's 315mm M3 discs and caliper brackets (using s14 calipers) MUCH MUCH cheaper than the 310mm bells and rotors route
dragging up an old thread but does it matter what year s13 the hubs and struts come from? are they a direct swap? are the brackets for s14 callipers still available from anyone? finally, the m3 discs, are they e36?
thanks in advance
Old 25-09-2009, 11:10
You can get everyting you need on either ebay or the SXOC (200SX owners club). I read the struts aren't a direct fit as factory S13 springs are too wide for S12 towers, requiring S13 coilovers.
I haven't tried yet so can't say from experience.
Old 25-09-2009, 13:50
You are correct in your speculations about the s13 standard struts are just toooo wide! I went down the road of doing a full s13 conversion (including the rears) and found the modifications to the lower arm mountings and tension rod mountings were fairly straight forward. By doing this i could use the s14a four pots and the larger facelift s13 discs (mintex discs and pads) the breaking efficiency is much improved over standard and after a few laps around the nurburgring the brakes although hot and stinking did not fade and if anyone has driven the ring it is not known for being a kind circuit to brakes! there were no modifications required to the ARB mounts as they lined up just fine. As has been mentioned before by rolling on the s13 hubs the braking options are blown wide open as most nissan fitment parts are fairly interchangeable (albeit with some minor modifications in some cases)
Old 25-09-2009, 15:58
Administrator
ah ok, not sure i wanna spend 600 quid on coilovers! well, not yet anyway
