Old 29-12-2007, 18:13
Dazz Dazz is offline
Default Strange Lumpy idle.
Ok, my silvia has always had a lumpy idle, it starts up fine but as soon as she's warm she hovers at 700rpm and flutters up and down, only about 50-100rpm at the most, she's always done it, she revs fine and pulls fantastic, i assumed it was old and tired spark plugs so today i finally got round to fitting a new dizzy cap, coil lead, ht leads and spark plugs set @ .9 gap, the idle is still lumpy, so ive got in contact with the guy who owned it befour hand and he mentioned a cam re-profile? he mentioned that this causes the car to tick over lumpy.
Befour i get loads of questions i'd just like to say the car never stalls, nor does it effect drivability, she pulls fantastic and doesnt spit out any smoke, well apart from the dying turbo it never causes grief but i just want to know if this is a problem?
And i want to say thanks to all who have helped me in the past, i aprecieate all the help you guys have offered.
Old 29-12-2007, 18:27
never got lumpy idle with my piper cam, but i had the same problem on my 2nd s12, but it would come and go, i had the same problem a month ago on this s12, but its cleared up its self.
Old 29-12-2007, 18:43
old-and-rusty's Avatar
Are you getting any fault codes showing on the ECU ?
I had a similar problem when I first re-built my ca18et, the throttle valve switch needed adjusting if I remember correctly.
Regards,
Ian.
Old 29-12-2007, 21:19
Regards,
Ian.
Whats a fault code do then?
Old 29-12-2007, 21:26
zxocmars zxocmars is offline
Oh dear
When you run the "self-diagnostic" function on the ECU it will give you codes for any problems that it may be sensing?
Search the forums for "ecu diagnostic" and I'm sure you'll find the instructions
Old 29-12-2007, 21:42
I'll give that a try in the morning, thanks.
