Old 18-09-2007, 13:01
lmrdave's Avatar
lmrdave lmrdave is offline
Default Air con removal
I'll be having the rad out on wednesday, so I was planning on ripping the AC out aswell.
Any problems just removing it up to the bulkhead? and taking the drive belt off?
Just thought I'd ask just in case!
Old 18-09-2007, 13:33
Thats how I did it mate. Mine wasn't pressurized so it wasn't an issue. If yours is pressurized you should bleed it off properly, but then I'd be tempted to just undo the pipes and see what happens instead
Old 18-09-2007, 14:05
lmrdave's Avatar
No idea if it's pressurised, will find out on wednesday.
Is there a cover plate on non AC'd S12's that I can put on if I take the condensor off, or can it just be removed and left?
Sorry for all the questions!
Old 18-09-2007, 14:13
I think the pipes still poke out the firewall an inch or 2 after you've undone the pipes. Could be wrong though, was years ago when I did it.
Old 18-09-2007, 15:19
lmrdave's Avatar
That won't be a problem they are well out of the way, I can soon plug them.
I'll might have a bit more time on it at the weekend, after I've fitted my new brakes, and springs and filled the front struts with oil all my bits came today woohoo!
Old 18-09-2007, 16:20
when i took mine out i took the whole lot, inc everything behind the dash as well, it didnt take too much longer
