Old 03-09-2009, 23:53
chris1986 chris1986 is offline
chris1986 is an unknown quantity at this point
Default Bee-r rev limiter on ca18et?
Hello guys i have bought a bee-r rev limiter and would like to know if and how i can hook it up to the ca18et?
And on wich wires i will have to attach it to?
Greetz chris
Old 04-09-2009, 00:15
Probably the coil earth I imagine. Got instructions for it?
Old 04-09-2009, 01:23
i dont have the instal manual
but i know this:
red wire = 12v power
black wire = ground
yellow wire = rpm signal
green wire = ignition signal
white wire = handbrake
so i only need to know is where to put the yellow wire and the green wire
have seen an installation manual for an ca18det but dont think the ecu pinout is the same
Old 04-09-2009, 01:26
I have a feeling the rpm signal is something to do with the crank angle sensor.
It looks like its done at ecu level. I'm sure with the DET instructions it can be worked out
Old 20-05-2010, 18:59
Dr Silvia's Avatar
sounds a little overcomplicated to me
from what you said sounds like this:
yellow to the +ve primary coil winding [refer to schematic for colour code]
green to acc on ignition barrell
no guarantees as theres no documents.
Old 08-06-2010, 22:47
steves12zx steves12zx is offline
steves12zx is an unknown quantity at this point
Sorry to bring back an old thread!
Just bought a Bee-r limiter for the S12 and was just wondering if you managed to et it sorted out or anyone else has fitted one?
