Old 26-01-2013, 19:41
Default lowering springs drop out of place ??
Hi I got a set of lowering springs from Silviagod and they are fine but I didn't know they were so low that they drop out of place when jacked up / full stretch. How do I stop this happening any hints tips would be appreciated.
Old 26-01-2013, 20:40
try cable ties might work
Old 26-01-2013, 20:57
hardly safe is it a piece of plastic holding them in
Old 27-01-2013, 11:31
check straps, use plastic coated steel cable, like on multi gyms, you can get it from b and q, and some tiny u clamps, loop each end with the u clamps, then drill a small hole near the shocker and then up near where the shocker mounts up top and bolt the cable to it, den (japster) on hear has this done.
Old 27-01-2013, 16:41
Default check straps
Ok sounds good i take it you mean this for front and rears?
Old 27-01-2013, 17:07
no, for the rears, what i did before i fitted coilovers, was make 3 little z shaped tabs for each side on the front, then drilled them n bolted them to to spring cup, top of the z shape hooks over the spring and botton bolts to the cup, this stops the fronts falling out.
