Old 12-07-2007, 19:50
mr_turbo's Avatar
mr_turbo mr_turbo is offline
Default Alternator
my fu*kin alternator has packed up again its not charging the battery for some strange reason n reali pissing me off checked alll wires n earths etc cnt find a fault anyone had as problem wid alternator before?
Old 12-07-2007, 20:14
Default As suggested on msn
a common fault on the s12 is that the charge wire from the alternator becomes corroded and causes resistance or even brakes.Mine did this,.
you should check the output directly from the alternator rather than just at the battery next
what i did to both was just run a new charge wire from the nut on the side of the alternator to the + terminal on the battery
thats my first guess at your problem, give it a go and get back to me
Old 12-07-2007, 20:20
yeah, was'nt japsters the same jon.
Old 12-07-2007, 20:38
yep,exactly the same problem Shaun
Old 13-07-2007, 14:58
mr_turbo's Avatar
tried that no luck ive sent ANUTHA alternator away for recon n that b wid me tomoz too c if that makes a difference i also noticed that the petrol lite and handbrake lite stays on wen i take key out so for some reason i have no idea why!! cor this is doin my head in
Old 13-07-2007, 15:09
Sounds like squirrels in the wiring loom!
Old 06-08-2007, 23:00
smoker's Avatar
smoker smoker is offline
I fitted a new alternator and ever since the petrol and handbrake light has stayed on after i take key out..did you find out what was causing this ??
