Old 26-01-2008, 02:46
WM-S12's Avatar
WM-S12 WM-S12 is offline
Default Fitment for Bride Recliner
Just wanting to know how to go about fitting a bottom mounted BRIDE recliner I've had for a few months now. I've tried before but realized the original mounts sit to close together resulting in only one side lining up where the bolts should be.
I was thinking about getting a custom made frame made up but there has to be a cheap reasonably safe way to get it to fit. Any one lend us a hand?
Old 26-01-2008, 18:49
Oscar's Avatar
Oscar Oscar is offline
get some steel and weld it in job done lol
Old 26-01-2008, 19:12
the s12 is a total cnut to fit aftermarket seats as the std ones are shaped to the transmission tunnel, so you end up sitting 10ft higher with the new ones.
Old 27-01-2008, 01:00
WM-S12's Avatar
Doesn't help I don't have a welder or know anyone who does.
must be an easier way, I've had them out and being a bride seat it's odd, the mounts are underneath and short not wide and the s12 is mounted just by two parts down either side of the seat. I've seen other mounts that are like a square, plus I fitted them on and tried putting it in the car thinking to small a gap. Fair enough, you can line one side up but your miles from getting the other side to even consider bolting down!! Maybe I should just drill the floor....kidding.
Old 27-01-2008, 01:06
i fitted some supra seat and they sat loads higher.
Old 27-01-2008, 12:52
WM-S12's Avatar
Only thing is if the seat end's up being raised I'll be squashed as my head already just brushes the roof in a normal driving position. Doesn't help when your tall.
Old 27-01-2008, 18:05
doski's Avatar
doski doski is offline
best bet would be getting some side mounted seats as you can change the height they sit at
Old 27-01-2008, 20:35
old-and-rusty's Avatar
Just leave the sunroof open....LOL...... .
Sorry, couldn`t resist it...
Regards,
Ian.
Old 27-01-2008, 08:53
....Maybe I should just drill the floor....kidding.
Not sure that would be so much of a problem if you used decent bolts and a small steel plate instead of a washer........ might be an arse to get the tools under the seat to do it up though.
EDIT - Just checked and thats how we did the seat in my MGB racer
