Old 12-11-2007, 19:33
Default Engine tune questions
Hi guys, me & a mate just bought an S12 and have done a huge amount of work to prepare it for next year. As can be seen here in the photo's
We want to use it for drifting so we have caged it all up, bucket seats, and welded the diff up to name a few mods. We have a few questions about engine tuning. We have fitted a massive FMIC so have increased lag.
How do you increase fuel pressure? can you fit a valve to restrict the flow back to the tank or is a 255lph pump the only way to go?
How do you increase boost to match fueling?
How do you know if it is running lean or not?
What offset and centres do the wheels have? or what oyher wheels fit? ie rover 200?
Many thanks for your advice in advance.
Hans
Old 12-11-2007, 20:49
get an aftermarket fuel reg ie: fse glenco fixed rate reg, you can increase the pressure behind the injectors, usually they run rich anyway, i ran 18psi on a t25 with a cossy i/c, so with that you should be ok, the cheap way is to run a cold start injector on a boss before the throttle body, with a pressure swith into the plenum, then have it on the dyno, they with check your fueling and timing etc.
Old 13-11-2007, 00:24
http://www.nissansilvia.co.uk/vbb/showthread.php?t=463
Nice work.Did you make the cage?
the nearside intercooler hose looks like it may be one for reguler 'pop offs' lol
Old 13-11-2007, 07:40
lmrdave's Avatar
lmrdave lmrdave is offline
Question for you: is that a bolt in cage or have you had it custom made or fabbed it yourself?
Good work btw looking good
Old 13-11-2007, 10:50
mr_turbo's Avatar
mr_turbo mr_turbo is offline
wheels are 4 by 114 with a 35offset basically most jap 4 studs will fit ie 4stud hondas etc
i want a cage like that where did you get it ?
what other performance mods has it got other then fmic?
what strut brace is that as well fanx?
Old 13-11-2007, 12:19
old-and-rusty's Avatar
Hi Hans,
That`s looking really good. Sorry I can`t offer any advice, but I would love to know, where you got your strut brace from as well.
Regards,
Ian.
Old 13-11-2007, 13:11
Originally Posted by old-and-rusty View Post
Hi Hans,
Regards,
Ian.
me to, that looks like it would fit the fj engine.
