Old 01-12-2008, 10:55
Question S12 boost issues
Hi guys,
Finally fitted my cossie intercooler, new plugs gapped at 0.9mm, MBC and setup the standard T2 to run about 10-12psi.
Was pulling really well but now have developed a hesitation at 4.5 to 5k like it's under fuelling but have checked fuel pressure and all within specs.
Car drives normally ok just when you plant it you get this stutter.
Also running on 98 ron fuel and timing is at standard.
Can anyone help as I'm at bit stumped ?
Thanks
Simon
Old 01-12-2008, 12:29
tractor-boy tractor-boy is offline
tractor-boy is an unknown quantity at this point
Air leak somewhere along the air intake? I was having the same problem and traced it down to that.
Old 01-12-2008, 12:31
I'll check the plumbing out when I get a spare minute.
Thanks for the heads up !
Cheers
Si
Old 01-12-2008, 13:03
ChEsTeR ChEsTeR is offline
chech the fuel preasure under load. On idle even a dieing pump will have good readings.
Old 01-12-2008, 13:29
FPR could be maxing out and for that matter the injectors too
Old 01-12-2008, 14:08
Wouldn't imagine they'd me maxing out at that, could be wrong though. Was running 12-14 psi with a saab intercooler, no other supporting mods and never missed a beat.
Old 01-12-2008, 14:35
Thanks guys I'll check all out when I can and let you know as maybe helpful to someone in future.
Cheers
Si
Old 03-12-2008, 09:36
Smile Sorted
Hi,
The pipe to the Fuel reg was split so replaced and all ok now.
It goes like sh1t off a shovel !!
Cheers
Simon
