Old 29-04-2007, 11:59
wacomuk's Avatar
wacomuk wacomuk is offline
Originally Posted by Pukkasilvia View Post
what fuel pump has been fitted to the car?
i would check this first. The standard fuel reg is non adjustable, the fuel pressure rises accordance with the inlet manifold pressure, if the fuel reg isn't receiving correct manifold pressure the fuel pressure will be affected (lower)(idle fuel pressure is 32psi from memory) check for cracked pipes
the standard reg could be past its best, try a FSE adjustable fuel reg or something similar
silviagod has had good results will the cheap jap ebay ones
are you the guy off locostbuilders??
