Old 02-07-2007, 12:49
Default changing the steering rack
has anyone changed the rack on the s12 with the engine still in ? if so is it a c*nt to do ? any tip what to remove, i've only striped one out with the engine out, i'am changing to the non power rack.
Old 02-07-2007, 17:39
Paul has done it and says its a cnut!
Old 02-07-2007, 20:30
Beany-s12's Avatar
i did mine and didn't find it too bad! but i was usin a pit! just undid the engine mounts and lifted the engine a bit! had to bend the pipes a bit to get the rack passed them so was a pain gettin them back in but u won't be usin them again anyway!
Old 02-07-2007, 20:32
cheers
Old 03-07-2007, 12:46
Getting the manual rack back in there will defo be easier.
Out of interest though how many turns lock to lock is it?
Old 03-07-2007, 17:30
i still need to change my rack as well........no pas and welded diff arent much fun for parking
i think the non pas racks are the same as the 910, 4.1 lock to lock i think?
Old 03-07-2007, 18:18
i need the non power rack for the fj as i will have a cd2000 exrernal oil pump bolted where the power steering pump would fit.
Old 03-07-2007, 18:51
Cant the oil pump be bolted lower down on the block?
If it is 4 turns lock to lock like my car its not going to be the best solution.
Old 03-07-2007, 19:15
i think it would be a little cramped, with an alternator and a oil pump on that side, i need to drive it off of the nose of the crank.
Old 03-07-2007, 19:17
Why not have an electric motor running the pump?
