Old 05-11-2007, 15:37
Ta for the welcome
Purchased (and waiting to arrive) a vag-com compatible cable from ebay so I can read/clear the fault codes for the VW Golf, as I believe it's in 'limp home' mode for some bizarre reason. If that's the case, means I can flog the clio asap and get the golf mot'd and flogged also (or drive for a while I suppose, but hopefully get an S12 )
Matthew
Old 19-11-2007, 13:04
Waiting for a OBD I diagnostic cable from Hong Kong to turn up so I can sort out why the Mk3 Golf automatic, I have in the garage is in limp home mode. Soon as that's sorted (if possible), I'll fix the brakes and MOT the car and use it whilst I fix the clio (clio's clutch release bearing needs replacing 'I think', the clutch itself seems fine as it doesn't slip. Just anything mildly spirited and the clutch pedal gets clicky and excessive force is needed to push it down). And then... can sell both cars
One step closer to a nice S12
Matthew
