Question for you: is that a bolt in cage or have you had it custom made or fabbed it yourself?
Good work btw looking good
wheels are 4 by 114 with a 35offset basically most jap 4 studs will fit ie 4stud hondas etc
i want a cage like that where did you get it ? what other performance mods has it got other then fmic? what strut brace is that as well fanx? Last edited by mr_turbo; 13-11-2007 at 13:40. |
Hi Hans,
That`s looking really good. Sorry I can`t offer any advice, but I would love to know, where you got your strut brace from as well. Regards, Ian.
me to, that looks like it would fit the fj engine.
Thanks for your advice guys, I will look into that and keep you all posted on the progress. That hose you said about has been adjusted and reclamped since the pics and should hold fingers X.
In answer to your many questions, I am a welder fabricator by trade for 20 years & have the added benefit of being the works manager at my workshop in Peterborough, cambs. So, yes, I did design and fabricate this non FIA cage and it is welded in as bolt in ones are weeker and more complex & therfore more time consuming. If any of you are local and have a spare £300 cash and dont mind leaving the car with me for a couple of weeks, let me know and I may be interested. I also made the strut brace ends and was donated an old Skyline alloy cross bar which worked a treat. Again, if some of you are genuenly interested then I may be up for making a few. Would be about £60 each, I would need a few orders to justify getting some alloy bar and tube etc.. I also made my own air intake box (though this is a one of due to head light conversion & relocating various components to make way for one of intercooler pipe)and MAF adaptor plate for the cone filter to bolt to, I can make loads of these in stainless steel for about £10 each. Cheers, Hans.
if your gonna use it for drifting i would advise fitting some steering rack spacers if you havent already, and if your going for 3rd gear+ probably a t25 for a bit more grunt?
Steering rack spacers...interesting....to get more lock to lock.
What do you recomend size wise? Cheers. |
