#21
the standard AFM is the same part as the s13, and it's proven to be good upto 270bhp
#22
Like I said Adz, if you get desperate there is one at my local scrappy. |
#23
do what you like, I'll not be trying to disprove anymore bullshit myths on here anymore |
#24
If using 3 bolts is so bomb-proof why do the come out of the factory with 4 then smart arse?
Do it Adz! After all if the French tuners do it, it must add at least a 1000bhp. |
#25
Look eveyone has there own views so lets just keep certain opinions that will trigger a conflict to ourselves yeah, i for one am getting fed up with reading arguements on this forum, im sorry but its not going to be tolerated time and time again.
#26
whats the point in a 220bhp renault 5? you can't use it properly because its fwd and like everything else french USELESS
#28
has everyone fallen ill with a bout of arsehole syndrome or something?
chill out folks. fact is, a t2 elbow can work. adz wants to use the t25 however... the main reason being because he likes everything to be perfect.... which i dont see a prob with. he's put a lot of time and effort into doing everything correct to the smallest details... various elbows will fit and work but its a t25 that he requires... |
#30
But i need more info (fuel pressure setting, MAF, ECU and boost troubles). Perhaps my next stage if info will goods .
