Old 05-12-2008, 22:18
Default Running rich - not starting at all ?
HI,
The 323 / s12 does not want to start..its running rich when it does and on 2 cylinders ? can anyone help ?
Thanks
Stephanie
Old 06-12-2008, 07:36
mine did this sort of thing when the fuel pressure reg was fubbered.
thats the only experience i have of running rich so far.
Old 06-12-2008, 11:23
yeah, same hear.
Old 07-12-2008, 23:05
We changed the FPR but its still the same....loosing patience here with this and looking at putting a pinto into it !!
Stephanie
Old 07-12-2008, 23:21
what about if the water temp sensor, don't they run rich if its reading the engine as cold.or maybe the air flow meter,have you got spares to swap about ?and every so often mine will flood first thing in the morning, all that i do is take the plug off of the water temp sensor and it fires up.
Old 08-12-2008, 10:54
broken injector nozzle. this happened to me
Old 08-12-2008, 11:32
over the years ive had dodgy distrib/distrib cap and poor earth to coil. cranked fine and injectors primed fine, but weak/no/intermittent spark so smelt and looked like overfulleing when was actually undersparking lol
Old 13-12-2008, 21:33
HI,
We have checked for feed at injectors and found both terminals to be constantly live and not pulsing.....what gives them the signal to fire ?
Stephanie
Old 13-12-2008, 21:40
Draconis's Avatar
Draconis Draconis is offline
The ECU is what sends the signal out. Beyond that, I am sure these chaps would know better. I dont get how only a couple will be firing constantly while others wont when you trace the wiring back and they all feed off the same couple of wires from the ECU from my knowledge.
Old 14-12-2008, 07:59
i think they have an ignition live, and pulse the earth, im sure i read that on here somewhere.
**EDIT** according to the manual, thay have a permanent live, and the earth is pulsed, not ignition live. (but still the same in the end )
