Old 15-12-2008, 13:48
Default my car wont start i need help??? :/
how do chaps, my car wont go
it turns over fine, good spark & fuel, it has a crank position sensor in the dizzy does'nt it? dont know if anyone is familer or known problom????
fuel pump is werrrrrrinnng away so i think thats ok, i have a walbro 255ltr per hour one on order anyway!
what can i check? i'm a bit stuck but need to persevere & get her going! it was running fine i feel somat may have broken down in the system somewhere
i have changed plugs & regapped them to just less than 1mm, new leads dizzy cap & rotor, fuel filter, it was running fine before changing these items but it was difficult to start, seemed as though fuel was'nt getting through or the spark was'nt igniting, but i've checked these & they seem ok, i have a multimeter to do other checks but i'm not sure where to start??????? any help is appreciated
i have'nt ran the ecu self diagnose yet as i'm unsure how to do it
Old 15-12-2008, 14:55
my boost hose than blew
Old 15-12-2008, 18:24
if there are any things i should check let me know as i may have overlooked something! i'm off to by a timing gun tomorrow as i have'nt got one!
is there any way of testing the sensors with a multi meter or shall i just try the self diagnose's, could someone tell me how to do the self dianose as i have a vaugue idea but no manual
Old 16-12-2008, 20:15
Right chaps the car is now running but a bit on the rough side, i think the timing is out! i'm buying a timing gun 2moro so that can be sorted fairly easily!
trouble is it runs ok if a bit lumpy when warm but when starting from cold its rubbish it takes at least 5 minutes of cranking the engine over until it catches then it's like its missing on some cylinders then as the car warms up it smooths out but it takes at least 10-15mins of driving for it too feel normal-ish???
any ideas chaps
Old 16-12-2008, 20:21
try starting it with the water temp sensor disconnected.
Old 16-12-2008, 20:34
funny you should say that! it started fine previously when the water temp sensor did'nt work & was'nt connected! now i've fixed it i'm having starting woes! whys that?
i'm going to do the self diagnostic on it 2moro
Old 16-12-2008, 21:12
water temp sensor makes it richer on cold start.
Old 16-12-2008, 21:48
i'll give that a go! it was runnig quite good before the boost pip broke, then i fixed that & the temp sender, gave it a proper service of all service items & fluids & now have starting troubles, i gotta crack this & go for a spin with a full tank of fuel
i want to start fitting my new components intercooler/boost controller (new-one) 255ltr pump & a few other bits & give it a good velet inside & out!
dear me!
Old 19-12-2008, 16:44
it seems to me that the choke/cold start is'nt working, what operates this & what do i do to correct it???????
where can i get a new temp sensor?????
i tried taking thetemp sensor off & its made no differance to starting the car?????????
Old 20-12-2008, 19:00
irish s12's Avatar
Default starting issue
the choke on my car has never worked and i've never had any starting problems.you might have a vacuum leak.
