Old 19-12-2008, 16:44
it seems to me that the choke/cold start is'nt working, what operates this & what do i do to correct it???????
where can i get a new temp sensor?????
i tried taking thetemp sensor off & its made no differance to starting the car?????????
Old 20-12-2008, 19:00
irish s12's Avatar
Default starting issue
the choke on my car has never worked and i've never had any starting problems.you might have a vacuum leak.
Old 10-01-2009, 18:30
i'm ill having starting troubles, i have a new temp sensor fitted (OE nissan part) i took the air regulator off & cleaned it & it did'nt help, when i removed it it was about 3mm open, it moves freely with a screwdriver, it says in the manual it can be tested off the car but i dont know how, i've heard it can be wired to work from a switch????? :/
i've changed my vac hose to the fuel regulator too as the old one was a bit hardend
i have some silicone vac hose in the post to replace othe vac lines but mine seem ok
its taking me 5minutes of cranking to get it going, then once warm it is'nt too bad, start fine once warm
i've fitted a new dizzy cap too
any ideas lads??? i need to sort it asap
Old 11-01-2009, 01:24
Steelballz Steelballz is offline
Steelballz is an unknown quantity at this point
maybe all the cranking has worn out the battery by now...check the charge on it, and the distilled water in the battery too with a hydrometer...
also, if all the vacuum pipes are ok, are they definately connected to the right connections???
sure all the gaskets are ok, ie the engine isn't losing compression while cranking....?
Old 11-01-2009, 10:36
battery is good, vacume hose are all fitted correct & compressions are good, i'm havin mild thoughts of taking it to a garage which i dont really tend to do due to a small budget & i've not found one that is'nt a rip-of, where i live anyhow!!!
i'm going to redo the ecu diagnose's 2moro & see what it throughs up
any way i can wire a switch to the air regulator/ficd thing! so i put a voltage to it to open it then turn it off to close it when the car is warm
Old 11-01-2009, 10:48
did you change the right temp sensor??? there are 2 on the s12 engine, one for the gauge (has one spade terminal) and one for the ecu (has 2 terminals in a plug)
just a thought.
have you checked the cold start bit is working, im sure if you take it off, and look through the pipe holes you can see the bit that moves open and close.
Old 13-01-2009, 17:22
yep took the bit off that has that metal slide in & it moves freely! the air regulator, i have a spare ficd thingy too, the bit that the pipe from the intake to throttle bodie goes too, if that makes sence
i've just changed the 2 wire temp sensor & the spade end sender to no avail :? both new nissan parts
i want to hit the car!
Old 09-02-2009, 17:58
an little update!
it still has this bloody cold start problom, i've checked the voltages on the temp sensor & its recieving 5volts, the air reg is recieving 12.43 volts
what am i missing????
i've done a self diagnose on the ecu previous to voltage checks & i can get the ecu to stop flashing now????????
if anyone could pop by to help me for an hour to see if i've missed something
i cant see my timing marks to well, 15 degrees is the 2nd dot from the right on the pully is'nt it??? & idle should be around 750-800rpm
PM me if you have any idea's, i'm so stuck
Old 09-02-2009, 20:44
whats your location? needs updating in your profile matey
Old 09-02-2009, 21:11
i'm in the midlands coventry so pretty central
i'll update my profile
