Old 08-01-2009, 17:16
silencing a seperate EG exh is perfectly possible and common on some of the 80s serious Porsche and Audi race cars. look at using 2 stroke moped/small bike silencers as they shoudlnt be restrictive. also be sensible with the outlet. point it at the tarmac below the car and a lot of the noise is 'lost' as far as db sound meters are concerned. have it sticking out the bonnet or at the kerbside will only cause the track noise nazis to get uppity lol
Old 08-01-2009, 17:21
dont need to think about an external wastegate at that power IMO. FAR worse issues to think about first, like management/fueling (you'll need bigger injectors) intercooler, exhaust.
A T28 from an s14 on the standard manifold should do what you're after
Old 08-01-2009, 17:27
yep agree with Danny, the fabrication aint worth the grief
Old 08-01-2009, 18:01
Its just a seperate exh from the wastegate itself to vent the extra gasses after the preset boost level has been reached. i think the yanks came up with the screamer term as once the ext wastegate opens the screamer pipe is essentially an unsilenced exh
ebay has loads of screamer elbows which arent the real deal (no performance advantage) they can sound a bit pants and often bugger up the idle/low speed running of the car. only way is a proper ext wastgate imho if you want to improve performance and reduce spiking
to stop them being loud, you can re-join the screamer pipe back into the main exhaust. best bet is to rejoin minimum of 5ft from the turbo though or itll be a restriction (two lots of exh gasses squeezed into one pipe straight after the turbo)
does that make sense? does in my head, but let me know and i will try and explain better
no I got that
Old 09-01-2009, 06:35
xxxadzxxx's Avatar
xxxadzxxx xxxadzxxx is offline
xxxadzxxx is an unknown quantity at this point
fueling is sorted, 444cc injecters, 255 pump and apexi safc all here and ready to go on, so is turbo and exhaust the next thing i should be doing. or have i over looked something?
Old 09-01-2009, 21:25
Yopu haven't mentioned intercooling (in this thread) yet ?
Old 09-01-2009, 22:12
xxxadzxxx's Avatar
lol, cut a large hole in the bonnet and mounted a cooler there at 45 degrees
