Old 27-05-2010, 11:14
If you wernt so far away i would do it here for you lol.Try a 6 sided cut down ring spanner rather than a 12 sided. It may work.Soak it in wd-40 over night beforehand.
Old 27-05-2010, 15:45
Dr Silvia's Avatar
wind the two nuts or half nuts onto the stud, tighten them against each other, then unwind the stud with the inner nut
Old 27-05-2010, 16:29
paulsilv's Avatar
paulsilv paulsilv is offline
will try these techniques and see how I get on
Old 29-05-2010, 19:12
paulsilv's Avatar
Took car down to VOSA (Mate works there) to get it up in the air to have a go with a cold chisel to get it off. Not enough room to see what you are doing from underneath without giving it a good old belt into something else and knackering it altogether.
Not enough room to get 2 half nuts on either, tried every combination of spanner socket headed things you can think of without success.
Going to have to take the lot off to make a little more room to have a proper go at it.
Pissed off is not the word
Old 01-06-2010, 23:28
paulsilv's Avatar
Managed to strip the turbo off again and get the offending item off with these.
http://www.irwin.com/tools/browse/sc...olt-extractors
These are the dogs bollox and had it out in 5 mins.
Now need a manifold if anyone has one as the inside vein on the turbo side is split.
Looking forward to getting this back together now to terrorize the local LOL
Old 02-06-2010, 13:29
that bit always splits doesn't it ?
Old 02-06-2010, 15:56
grind the webbing out paul,as caminhead say's, they allways crack.
Old 02-06-2010, 20:45
paulsilv's Avatar
good shout guys, had that idea initially but thought it might crack the manifold further, will give it a go.
Its better out than snapping off and ending up in the turbo
