Go Back   S12OC UK Forum > Main Categories > Daily Chat
Old 19-10-2011, 20:38
tim murphy's Avatar
how is your silvia going bigdave have you done much to her laterly cheers
Old 19-10-2011, 22:55
tbh not much. Last thing i did to it was completely strip out the interior and got the back bumper off. The back wasn't as bad as i was expecting so its ok.
The state of my garage and the cold is putting me off doing work. Think i just have to man up and crack on with it lol. Also read that bilt hamber rust prevention products dont work well in temperatures lower then 10 degrees c
What about yours mate hows it going?
Old 20-10-2011, 22:14
tim murphy's Avatar
am in the same boat working outside on her wind blowing a bitch and cold took off fuel pipes and exhauts claps one snap bolt not to bad try to get one job none at a time 2 mos starting on sand blasting if dry cheers ps keep doing one thing each day
Old 20-10-2011, 23:55
I was thinking about sand blasting the other day but have no clue on how to go about it or the equipment etc. do you have any tips or guides?
Old 21-10-2011, 23:01
tim murphy's Avatar
hi am useing a compresser and a sand blasting kit with grit small problem with blasting gun not the right hose clamp will work out good in small areas and can reuse the grit let you now how i get on with it 2 mos dave cheer ps good two see ours silvias back on the road in notts .
