Old 25-11-2012, 20:50
paulsilv's Avatar
paulsilv paulsilv is offline
Default S12 baffled sump
Does anyone have one laying around, or know of a company that will do it.
I have a spare one from the old ET that was pulled out to make way for the DET.
Will an ET one fit on a DET?
Is there anywhere that does aftermarket ones?
Old 25-11-2012, 21:02
not sure mate but i know that the det one fits the et block, gripo's has got it on, i know that from when japster had it.
Old 26-11-2012, 00:12
paulsilv's Avatar
Cheers Shaun, I know Japspeed sell the winged ones for £110, but not for the DET.
I'm sure it could be done a lot cheaper by a good local welder or engineering firm.
Just need to read up on baffled sumps to come up with a good design and get it made.
Old 27-11-2012, 17:34
paulsilv's Avatar
found these 3 links:
http://www.sxoc.com/vbb/showthread.p...highlight=sump
http://www.sxoc.com/vbb/showthread.p...hlight=peugeot
http://www.sxoc.com/vbb/showthread.p...ge-observation
Now my heads a shed
Old 28-11-2012, 21:43
Ok, my two penneth.
The ET sump is a better design imho than the later det version. In my opinion nissan were worried about the 16v head reatining oil and not draining back to the sump so the added loads of louvres in the splash plate to allow oil flow back into the sump pan, and cut away more material around the pick up too. Trouble is that when the grip and or performa ce is increased, the oil can forced away from the pick up under cornering/braking etc. The louvres also allow the oil to surge to the back of the pan and away from the pickup under hard acceleration.
If you are using a det sump, i reckon closing up every other louvre and added a plate around the pickup copying the ET version.
If you add wings, be careful, as you will need trapdoors that are sprung ( see niscorts posts or the ally greddy SR winged sumps) or the extra oil will just surge and end up splashing all over the crank causing other issues.
Ive bought an accusump instead, just to give 10-15seconds of oil direct into the main gallery if i get surge
Old 28-11-2012, 21:56
mt s12 is back together tomoz mate, so time for a play before the snow comes
