Old 12-04-2006, 17:31
Default pcv
i dident want the dirty oily air from the pcv hose going back thru my turbo and engine, so i blanked off the hole on the inlet pipe with a modified wheel nut, and fitted a oil catch can, an old oil container i cut the lid bigger than the size of the tube so the air can flow through and cable tied some stuff is this alright/effective
i need to tidy/clearout my garage
Old 12-04-2006, 18:00
that will work ok , but it's not the PCV, that's the one that comes out of the crank case and goes into the inlet manifold. Ideally you would block the PCV valve and run a hose from the crank case breather to the same catch tank
Old 12-04-2006, 18:09
yeah i was just looking thru club-s12 and realised
Old 14-04-2006, 21:36
rob turbo's Avatar
just put a breather filter on the end where the crankcase lid is... spot on that. did that myself, you can get breather filter for next to nowt..
