Old 01-05-2006, 17:29
Default cam timing
here's a question for you, i'am fitting a new timing belt but i'am a bit it shows in the book on em-6 that the pointing arrow points to the first notch on the bottom pulley, but i'am sure that last time i set it on number 2 notch, i'am sure 30psi said to use numbur 2 notch as well if so why is this.
Old 01-05-2006, 17:39
Dr Silvia's Avatar
the drawing is not 100% accurate shaun if you count backwards from 20deg. mark then the mark shown is tdc, no2 as you count it
Old 01-05-2006, 17:45
thanks doc, i thought so, but just had to be 100%.
Old 01-05-2006, 21:52
For anyone thats read this and thought WTF is shaun on about he refers to the timing marks on the bottom pulley.
There are 6 marks
From left to right:
5 ATDC, TDC, 5 BTDC, 10 BTDC, 15 BTDC, 20 BTDC
ATDC - After top dead centre
TDC - Top dead centre
BTDC - Before top dead centre
Old 04-05-2006, 22:58
i'll sort it soon.
