Old 29-07-2006, 13:57
Ronin's Avatar
Ronin Ronin is offline
Silvia Driver
Default Headlamp Relay
Is the black relay mounted on the airbox mount the relay for th headlamps as my headlamps work on sidelights and main beam only and when they are on dipped beam this relay makes a loud clicking soud that can be heard inside the carwhilst driving.
Any help appreciated.
Old 29-07-2006, 18:40
i think there are 2 black relays there, i think (dont quote) they are for left and right switching from dip to main.
Old 29-07-2006, 19:06
Ronin's Avatar
Silvia Driver
Your thinking of the front of the airbox mount I'm looking at the rear where it mounts onto the suspension turret.
Thanks any way.
Old 29-07-2006, 23:48
ahh ok m8, sorry then im not sure. i dont have an airbox
Old 30-07-2006, 05:36
ianv72's Avatar
ianv72 ianv72 is offline
ianv72 is an unknown quantity at this point
i have this problem on my s12 , check my ebay sale for the g reg s12 . an auto electrician traced this problem back to the headlight arm / stalk or whatever you want to call it , bad connections . the reason the relay clicks is because ther isn't enough power going through it to click it into place . i aint no sparkie mind you but thats what i was told so i assume it to be right . my lights work on sidelight and main beam , but very very dull on dip and the relay clicks , sometimes though this changes to one light working on dip and the other going out completely
Old 30-07-2006, 17:57
FLEXXX's Avatar
FLEXXX FLEXXX is offline
ive checked on silviagods website and he mentions that it was a common problem on later models he suggests that you change the stalk first before checking the wiring hope this helps
Old 30-07-2006, 18:17
i had posted this on all other threads, always look stalk first, i assumed he had done a search before posting, sorry.
if you know someone see if you can test swap the light switch first.
Old 30-07-2006, 19:09
Ronin's Avatar
Silvia Driver
I've already checked the switch and got good contacts for dipped beam, so any other Ideas?
Old 30-07-2006, 20:29
bulbs, fuses.
but i would still try a stalk anyway just in case, mainly to put your mind at ease.
Old 30-07-2006, 21:04
Ronin's Avatar
Silvia Driver
Bulbs and fuses are all ok, all the stalk does is control which switches are on via a cam, these are all working ok with good contacts.
