Old 02-08-2006, 22:30
I used a webber one as used on the sierra cosworth.Its adjustable and reliable.
Old 03-08-2006, 08:36
turbozx turbozx is offline
cheers for the replys, iv been scratching my head thinking about how to install the injectors, and have a few ideas
1. Fabricate a fuel real from aluminium bar and get it welded etc as many people have done
2.Make a fuel rail using high quality fuel hose and metal t pieces, i seen this done on a few engines buy professionals, easy to do but what do you think?
3. try and adapt the original CA18ET fuel rail
Personally i like option 2. as its the easiest and cheapest ill see if i can post a picture to show you what i mean.
Any body got any thoughts on this?
Old 03-08-2006, 08:43
Heres the picture of the "flexable" fuel rail
Old 08-08-2006, 13:26
anyone got an opinion on this?
Old 08-08-2006, 13:34
It will work providing it don't leak
Old 08-08-2006, 15:03
good quality pipes clamps and t pieces should do the job!
Old 08-08-2006, 17:56
ive just got a bit of bent pipe with little bits welded on for the injectors
Old 08-08-2006, 20:25
ok cheers, now iv got all the bit together now and am going to install the apexi this weekend the injectors some time after that, when i do install the s13 injectors obviously i will need to play with the apexi safc
i plan on getting it set up by proffessionals to get the optimum performance from it but as an initial set up to make the car drivable if i reduce the fueling by 27% at each rpm point then will that be ok
27% come from the fact that s13 injectors are 27% bigger than standard
iv also fitted an s13 tb so i can use the TPS so it can be mapped for part throttle.
an advice from anyone who has used this would be appriciated
Old 08-08-2006, 22:09
also do i need to use the dropping resistor with the s13 injectors?
Old 10-08-2006, 10:12
You are correct the adjustment is -27%
Even if you didnt use the s13 TB, the TPS's are interchangeable. I guess you'll have to wire it directly to the SAFC.
Nope, you dont need the dropping resistor
