Old 09-08-2006, 20:34
Default Sandwich plate
Anyone tried fitting one of these ? What do you guys reckon as they are quite cheap
http://cgi.ebay.co.uk/Anodised-Oil-T...QQcmdZViewItem
Old 09-08-2006, 21:11
Back Seat Chatter!
i'm looking to get a sandwich plate for my oil. cooler as well, and after some research, this is what i've found.
Here are the specs of the oil filter, so you need to find one that's got the proper diameter so the rubber seal with actually seal, and also you have to match the thread pattern.
Gasket I.D. (Inches):2.01''
Gasket I.D. (mm):51.054mm
Gasket O.D. (Inches):2.49''
Gasket O.D. (mm):63.25mm
Height (Inches):4.067''
Height (mm):103.3mm
O.D. (Inches):3.234''
O.D. (mm):82.14mm
Style:Spin-On Lube
Thread Size (inches):3/4-16
As long as those things check out, there shouldn't be a problem. Keith on club-s12 is running a sandwich plate on his car for his oil cooler as well. I believe he got it through a company in the USA called Summit Racing tho.
Old 10-08-2006, 03:22
keith keith is offline
S12oc Newbie
keith is an unknown quantity at this point
Yeah, I bought it from Summit, but the brand is by Perma Cool...... www.perma-cool.com
Here is my set-up...........
http://www.cardomain.com/ride/675796/7
Old 10-08-2006, 07:52
Nice setup!
Old 14-08-2006, 10:52
Yes i have one exactly the same fitted at the moment.it works fine. I siliconed in the blanking plugs that were supplied for if i wasnt using all the sencor ports.i had to do this as the blanking plugs werent taperered. that was my only gripe.....
