the standard one is like 42mm right? heh
Thanks for getting me those specs. That's quite a big difference from inner to outer diameter. The walls must be very thick.
![]() Quote:
on topic but different question, will it make any difference having the DET throttle body on an ET, im putting on the T25 soon, and thought this could be helpful if its worth doing??????
Cheers.
iv done it didnt really notice much difference, probably give 5bhp and helps with top end breathing worth doing in my opinion
The ka24e throttle body is a better route...but then again I'm in north america, so they're pretty plentiful here.
Those are about 60mm.
![]() Quote:
or get a Z31 turbo TB like mine which is bigger than the
S13
![]() from memory: CA18ET - 48mm SR20DET- 54mm CA18DET- 56mm SR20DE - 60mm KA24 - 64mm might not be entirely acurate |
the fj has a 56mm internal at the rear and a 70mm internall at the front, so it has a nice ramming effect, and i've got a couple.
