Old 11-09-2006, 11:25
s12Rob's Avatar
s12Rob s12Rob is offline
Default Went Up In Smoke
right have a slight issue with my s12, was playing with a calibra, pissed all over him and then had lack of power and big cloud of smoke behind me, cam belt isnt snapped or skipped teeth, runs but sound like only on 2 cylinders. im thinkin piston rings but not certain, any advise would be apreciated
Old 11-09-2006, 11:28
Did you top speed it?
Sounds like a holed piston to me. Remove the oil cap and see if it spits lots of oil out due to the excessive crank case pressure
Old 11-09-2006, 11:36
s12Rob's Avatar
i was doing about 140 when it happened, smoke comes out the oil filler cap, white smoke
Old 11-09-2006, 11:39
Sounds about right.
What spark plugs are you running?
Old 11-09-2006, 11:42
s12Rob's Avatar
the colder ngk ones bcpr78es or sumthing liek that
Old 11-09-2006, 11:49
Hmm, using them should stop the problem unless there is something wrong with the timing or fueling.
This is the expected damage:
I would do a compression test to tell. I suspect you've got damage to number 3.
Old 11-09-2006, 11:56
s12Rob's Avatar
the timing has been retarded from what i was told to 15deg btdc. i am running 11 psi tho
Old 11-09-2006, 12:04
Well 15 degs is standard.
Are you running an intercooler?
Old 11-09-2006, 13:43
had excatly the same thing but on a toyota corolla,it happened at 5500rpm and smoke was pouring out the breather on the rocker cover,when stripped down it was a holed piston
Old 11-09-2006, 20:16
grim sorry to hear that
s12s dont like doing 135+ with the standard fuel pump and increased boost.
i suspect you have holed a piston or at the least blown the head gasket.
chuck a 50 quid replacement engine in her.Put a wanted ad up
