Thanks for the reply, that is about the only thing I haven't checked. I will have a feel of my shaft tomorrow and see what it feels like. The turbo spools up well though, I get good dumps and the car doesn't use any oil. Also there is no water in the oil or oil in the water.
![]() All jokes aside my car is misbehaving since the cold weather aswell, my temp gauge is wondering and the heater blows hot when it wants too so i think its new thermostat time. Also though its been making extreme boiling noises when at idle and its hesitated a few times on boost, its as if its low on fuel when im boosting it which is causing it to act like a missfire. Just feels retarded. It steamed/smoked alot when slowing down and when i parked up so a compression test is in order aswell although no mayo is present in the oil cap and dipstick looks normal too. I know my turbo isnt great and has been on its way out for a while now so i dont suppose this is helping matters on boost.
![]() Currently 226.4bhp@13psi with a remap to 18psi coming very soon ![]() |
Paul I have had to change my air choke idle thingy as it was *ucked! and wasn't working which gave a funny idle. Maybe its broke/not working properly. Also on the IAA thingy there is Two plungers which open when the idle goes low ie when the lights are on etc to let more air in. These gave me strange idle probs on my old Cherry Turbo. Undo them and clean them out! You've checked all the obvious so nows the time to step back and think of the Not so obvious!
Thanks Steve but I have tried a different clean IAA unit and it made no difference and the auxiliary air valve is working fine because the tick-over is perfect until the car warms up.
ADZS, the thermostat is working fine and the temperature gauge goes to the middle as per workshop manual. Hopefully a friend who has a MOT garage may be able to check the injectors on the car with an oscilloscope and tell me if one is acting the goat as the lumpyness is not every fourth time like a proper misfire. |
My gauge never goes past a 1/4 of the way up the gauge as my twin kenlo hurricanes dont allow it too
it is the thermostat that controls how far the needle goes not how big the fan is. The needle may go higher if the fans are thermostatically controlled.
The fans are on a manual switch which are on 99% permanently.
