I dont understand from your posts if you changed the thermostat or head gasket and youve mentioned swapping heads
Well he holed a piston a while back i think so i imagine he took the head off and put it on a different bottom end.
Have you done a compression test? I predict it will blown again as Every ca18et ive known that hasnt had the head skimmed on hg replacement has blown the hg again with a few thousand miles at the most.
ally heads can warp just by taking them off incorrectly. its always advisable to surface a ally head before refitting
i thought that u only had to skim the head if the gasket blows, not if changing it. i have a spare head i can use and swap manifolds
well why did you change the head if the gasket hadnt blown?
when ever you take a head off skim it, it cost next to nothing and can save you soooooo much agro......trust me £1600 later.
IM OFF LINE FOR A WHILE SORTING OUT NEW CAR/HOUSE/JOB
IM BUSY AS F**K |
Did you not skim the head on your Bentley when you took it off then?
