Old 20-11-2006, 20:19
mr2sc89 mr2sc89 is offline
mr2sc89 is an unknown quantity at this point
yes have spark and fuel while turnin over.
Old 20-11-2006, 21:14
Cam timing
Valve clearances/Rocker shaft
Ignition timing
Vaccum Leak,
Air flow meter
Ecu
fuel pressure regulator
Bad Fuel
Thats about all the possabilies i can think would be possable
Old 20-11-2006, 22:58
smoker's Avatar
smoker smoker is offline
I had the exact same problem, everything checked out ok.. i would bet £10 that if you heat the plugs with a blowtorch or on an arga then pop em back in it will fire up .
Also on mine the switch on the throttle had stopped working so my timing was way out so that could be worth checking.
Old 21-11-2006, 23:10
i checkd the switch and seems to be working, power and continuity checks out? also i think ive just blown up the coil with all that starting. there is now a crack in the side and it sparks when it wants, so does any body know where i can get one at a reasonable price, and maybe plug leads?
Old 22-11-2006, 17:59
Try taking out the fuel pump fuse and then turn it over for a while and put it back in. Also under the Air box is two plugs around 6/8 wires. Check these as one of mine was rotten and was causing all sorts of probs on mine. Also Paul (silviagod) had a prob with his FPR on the rail so check the pressure!! Good luck!
Old 24-11-2006, 15:55
smoker's Avatar
I don't think coils are generally available except from Nissan ££. I have heard of people in the states using erm MSD Blaster ignition coils?? which are supposed to give a stronger spark. Should be cheaper than the Nissan item i expect. I pulled a coil of a scrapper a few years ago for a few quid.
Plug leads are available from most motor factors but the boots are too short so not as good as the Nissan items but much cheaper. Someone more knowledgeable pls correct me if i'm wrong
Are you sure it's the crack in the coil not fouled plugs etc. that's causing the sparking problem ?
