Old 26-11-2006, 13:09
i just got the flow bench chart, it flows 152.1cfm.
Old 26-11-2006, 14:12
If you look at the designs of the paths, leading from outside the head down to the valves, there is very little change of direction. The inlet side goes in at like 30 degs downward towards the valves, so there is very little change of direction of the airflow, especially as the valves are angled themselves. Its a much better head than the CA18DET and SR20DET.
Old 26-11-2006, 19:24
just been talking to Ben at Angelworks and he says the peugeot s16 head flows 150cfm at 10" as standard and can gain 15cfm with 5 minutes work. what pressure was it done at?
Old 26-11-2006, 19:30
what cams are available shaun for this head?
Old 26-11-2006, 19:52
the cams are tomei 288 duration and 10.35mm lift.
Old 27-11-2006, 09:13
nissan_turbs nissan_turbs is offline
nissan_turbs is on a distinguished road
Bloody hell Shaun, 1000 bhp? Has to be done!
Out of interest, what did you ET head flow?
Old 27-11-2006, 09:24
stock one -around 87cfm ported one -97cfm
Old 26-11-2006, 19:51
not sure what pressure it was done at, but andy has done a peugeot 16 valve turbo conversion in a 205 and he said that the fj head is flowing slightly more air than the pug on his flow bench,but there are more higher lift cams availible for the pug.
