Old 27-11-2006, 02:15
Dez Dez is offline
Hi, i'm new. Sounds like you know your stuff all right. I'm a mechanic myself and i'm puzzled. Check the ignition timing with a timing light, you might have a spark but the timing could be wrong. Also check the main relay, it connects your ignition and fueling to the ecu, if it's faulty, the ecu won't know how to balance the ignition to the fueling, upsetting the timing, and the car will not run. This would usually bring on a fault light which may be the light see on the ecu. Only other thing i can think of is that the ecu has blown but it's unlikely. Hope you sort it mate!
