Old 28-11-2006, 23:18
Beany-s12's Avatar
do the s13 injectors fit in easily then and do u need higher fuel pressure to make them run effectively? i'm only running a t25 so noy sure if they need changing but def feels like its leaning out at top end! would be interested in a chip if availabe but would the car need to go on a rolling road to set the car to the chip for better results?
Old 29-11-2006, 00:25
The S13 injectors flow more fuel at the same pressure, so no change is required. It is beneficial and safe to run a walbro pump though.
Old 09-01-2007, 23:53
emulator arrived and got it working with the mapping software today. short of a car to do anything with now though as the 190k bottom end gave up the ghost on sunday. Doh. hoping to find something i can do some experimenting with asap now
Old 10-01-2007, 00:32
What happened to the bottom end? Anything spectacular?
I really want to hear that a s12 ecu has been remapped, there must be someone out there with a healthy setup.If i still had my old 8v setup i would be jumping at the chance
Old 10-01-2007, 01:08
nothing spectacular except for the noise :
I'll 100% be mapping the ECU for Lous new engine when it's done but it won't be suitable for sharing round. I think it would be much more sensible to do any mapping as 1 off as there aren't really that many same spec cars around
Old 10-01-2007, 09:18
alundra alundra is offline
Nice nice !
P.S: in your ecu mapping does the 4 or 8 spark plugs system differe or doesn't matter?
Old 10-01-2007, 12:41
Originally Posted by alundra
Nice nice !
I think I've answered this 5 times now the ECU is different and the pictures you sent me did not have a 28pin eprom present in the ECU.
I've never touched an 8 spark s12
