Old 03-12-2006, 02:37
Dez Dez is offline
Well if that solves the problem, there's a 95% chance the main relay is sticking.....
Very very common problem.
Try it anyway, you can do no harm by checking a relay.
I'm not sure myself where it's located but, it should either be close to the ignition or beside the ecu. It'll probably be different to the rest.
Old 06-12-2006, 12:59
smoker's Avatar
smoker smoker is offline
Thanks for the replies . I tryed a push start with the key out and no start so I guess the ignition switch is ok. Does sound like a relay sticking I can hear something click under the speedo sometimes when I switch off . Trouble is It looks really difficult to get to without putting my back out so think i'll check the relays under the bonnet..seems to be alot so should be fun
