Old 04-12-2006, 20:59
the number on the insert is 365013 d126 kyb.
Old 04-12-2006, 23:18
Umpkin
When you come to get the instrument panel I'll show you the Datsun coz the S13 coilovers are in. I reckon front coilovers with Z32 brakes will cost about £350-400. You should be able to find S13 fronts for about £200-250, and a set of Z32 discs and calipers for £150.
The issue with the homebrew coilovers is that you are running the KYB at the very bottom of its travel. With S13 ones, they're designed so the travel is correct, and therefore they wont bottom out. The height and preload adjustments are seperate on proper coilovers as well
