#11
will have to see about trying to get a blueprint one off the net as we dont have any stockists here on the isle of man....
there was some blueprint ones on ebay but missed them will have to see if any more get posted
#12
i rang my local motorfactor that ive used for years,he said he can see why your having a problem the stockists he uses only have 1 in stock,its £44 from him
#13
rite will look into it thanks
#15
Any bearing stockist should be able to supply the bearing's if you quote the number stamped on the outer race. It's usually something like NTK or NSK
then a load of numbers. Not seen the bearings though so i can't be sure
