Old 05-12-2006, 21:43
wacomuk's Avatar
wacomuk wacomuk is offline
no but you can get a ATB from quaife
Old 05-12-2006, 22:22
And if you don't have £600 spare for a Quaife then you can use an S13 LSD with some other bits, for very little money.
Old 06-12-2006, 02:13
Dez Dez is offline
Dez is an unknown quantity at this point
600?..... .....Thats over double what i paid for the car - S13 it is then.
If anyone who has used and S13 diff could post up some picks of it, plus extra
parts i need - i would really appreciate it.
Thanks
Old 06-12-2006, 08:31
Fully strip the S13 LSD, and removing the ring gear from it. Throw ring gear, case, shims etc in the bin
Then strip the S12 diff, and rebuild it with the S13 inner diff unit. ie bolt the S12 ring gear to the S13 unit.
Then the shafts need some work.
You use the short S12 shaft on the driver side with the S13 inner joint/inner
On the short side (passenger side) you can use the standard short shaft but you have to remachine so its like the S13 shaft.
Old 06-12-2006, 12:36
Sharas's Avatar
Sharas Sharas is offline
Cant the left output shaft be used from the s13/s14 diff?
Old 06-12-2006, 12:54
No because it makes the shaft too long, and it full compresses up the cv joints and it even pushes the swing arm outwards
Old 06-12-2006, 12:59
Sharas's Avatar
Got that, well i think that wount be a problem (first i need to make the car runing again , now thats bit of a problem)
