Closed Thread
Old 05-12-2006, 22:43
no but you can get a ATB from quaife
Old 05-12-2006, 23:22
And if you don't have £600 spare for a Quaife then you can use an S13 LSD with some other bits, for very little money.
Old 06-12-2006, 03:13
Dez Dez is offline
600?..... .....Thats over double what i paid for the car - S13 it is then.
If anyone who has used and S13 diff could post up some picks of it, plus extra
parts i need - i would really appreciate it.
Thanks
Old 06-12-2006, 09:31
Old 06-12-2006, 13:36
Sharas's Avatar
Sharas Sharas is offline
Cant the left output shaft be used from the s13/s14 diff?
Old 06-12-2006, 13:54
No because it makes the shaft too long, and it full compresses up the cv joints and it even pushes the swing arm outwards
Old 06-12-2006, 13:59
Sharas's Avatar
Got that, well i think that wount be a problem (first i need to make the car runing again , now thats bit of a problem)
Closed Thread
