Old 24-12-2006, 18:22
s12Rob's Avatar
s12Rob s12Rob is offline
thats between me and brad, he told me he hasnt got an adress for me to send the money to. so untill that gets sorted, head is already off as head gasket went, head being skimmed. cam belt, new bearings, new rings, sump gasket, rocker cover gasket. t28 turbo, front mount being piped up before she comes on the road. am hoping for about 200+bhp at 1bar
Old 24-12-2006, 19:56
Ok mate. im just trying to look after a friend of mine. What front mount intercooler have you got to go in? are you going to getting rid of the mechanical radiator cooling fan too?
Do you not thing the car came on along way in the few months that it was down this way? It was far from finished but it saved you alot of panelwork etc. It must of been like a different car when you got it back
Old 24-12-2006, 22:52
s12Rob's Avatar
oh yeh dont get me wrong, there was a lot of work gone into the car, wasnt too impressed with the exhaust with the samco on it and the respray but hey was a good price.
got a pace ally intercooler, yeh got sierra twin elec fans to go on, gunna wire them up to the air con switch
i think im gunna try and re-spray it myself at work, needs few bits fillering. how was the spoiler fitted as thats coming off.
Old 25-12-2006, 00:30
I wasnt too impressed when we picked it up from you that you forgot to tell us it had to be started with a screwdriver or did it not having an ignition barrel slip your mind
Old 25-12-2006, 13:30
s12Rob's Avatar
i did actually say to brad in a msn convo that it needs a full lockset, wouldnt that make u think it needed one??
anyway lets not get into this again, back onto topic. what actuall work needs to be done to make this fit from a std t2 to a t28, ive got the exhaust flange, pipe for oil lines, what abuot water?? and does that lug need to come off the gearbox or will it be ok?
Old 25-12-2006, 13:39
Well if id known it needed one i wouldnt be saying it now would i so less of the cheek
You need to remove the lug yes because the downpipe interferes with it, what oil line have you got as a std t2 one wont fit, water lines is up to you really but hardly anyone bothers with them as its basically hot water cooling the turbo so seems pretty pointless in my opinion.
Old 25-12-2006, 16:19
s12Rob's Avatar
ill use the oil lines that are still on the turbo, cut them and run some hose to the s12 oil feed, happy days, think i mite just take the water pipes out of the equasion. as u say no point in cooling a turbo with warm water, but surely it helps????
